Common problems
Starlink Repair & Support · Southern Highlands
The most common call we get. Slow speeds, constant dropouts, or Starlink simply stopped working — almost every problem has a cause we can find and fix. We service Bowral, Mittagong, Moss Vale, Robertson, Bundanoon and all of the Southern Highlands.
Most Common
Usually caused by dish obstruction — trees, rooflines, or even a new structure. We use the Starlink obstruction data to find the cause and relocate or raise the dish to restore a clear sky view.
Speed Issues
If your Starlink isn't in bypass mode, you're losing significant performance. We reconfigure your installation to run through a quality router in bypass mode — often doubling real-world speeds with no hardware cost.
Coverage
Starlink delivers fast internet to one point — getting it everywhere else is a separate job. We extend coverage with enterprise UniFi access points and wireless bridges to reach every building, shed, and paddock.
Setup
New Starlink kit arrived and you're not sure how to set it up properly? We handle the full installation — dish positioning, mounting, cabling, bypass mode, and integration with your existing network.
Serving all of the Southern Highlands
Bowral · Mittagong · Moss Vale · Robertson · Bundanoon · Berrima · Exeter · Sutton Forest · Penrose · Kangaloon · and all surrounding rural properties
Self-Help
Work through these steps — they fix the problem more often than you'd think. And if they don't, we're genuinely happy to help with small issues as well as large installs.
Intermittent disconnections
Still dropping out after trying these? It's likely a signal, hardware, or configuration issue we can diagnose remotely.
Not getting what you're paying for
A properly configured Starlink installation in bypass mode with a quality router makes a dramatic difference. We do this on every install.
No signal in certain rooms
Dead zones in large or heritage homes almost always need a proper access point design. We can map your property and quote a permanent fix.
WiFi won't extend to outbuildings
Connecting outbuildings is one of our most common jobs — wireless bridge or cabled. We'll tell you which is right for your property.
Reconnecting constantly
Persistent disconnection issues often point to a configuration problem we can sort out quickly — sometimes remotely.
Paying for speed you're not getting
If you've tried these and you're still not getting the speeds you're paying for, there's almost always a fixable cause. Let's find it.
Still need help? We're genuinely happy to assist.
We work on small issues as readily as large installs — and small jobs often reveal bigger opportunities worth knowing about.
Free Tool
Create a scannable QR code for your network in seconds — perfect for Airbnbs, guest rooms and offices. No app, no typing passwords.
Security alert
Most people carefully lock their doors and carefully choose their passwords — then connect a $50 smart plug to the same network as their laptop, bank app, and business files. Here's what that actually means.
Smart home and IoT devices are designed to be affordable and easy to set up. Security is rarely the priority. Many ship with default passwords that never change, receive infrequent firmware updates, and send data to servers in countries with limited privacy protections.
Common culprits on your network right now:
…everything on the same network is potentially visible. An attacker who gets into your smart TV can scan your network, find your laptop, your NAS drive, your business files, and your other devices — all from your lounge room.
Many solar inverters connect directly to the internet and are rarely updated. They've been used as entry points to home networks in documented attacks — and most owners have no idea.
Proper network design solves this completely. By placing each category of device on its own isolated VLAN, we ensure your vacuum can still talk to the internet — it just can't see your laptop. Your solar inverter can still report to the cloud — but it can't reach your files.
IoT devices, guest devices, and your personal devices each live on separate networks. A compromised smart plug can't reach anything else. Your sensitive devices stay protected, automatically.
VLAN segmentation isn't an optional extra for us — it's part of every single installation we do. We typically set up:
We'll get back to you within one business day.
We aim to respond within one business day.
In the meantime, feel free to call us on
02 4879 9717
